Help me! xr650r determine the cause of knocking
Re: Help me! xr650r determine the cause of knocking
Sounds like cam chain and valves ?
Mauser wrote:Sounds like cam chain and valves ?
I dismantled the whole engine and the worst thing that I could find
I replaced the rocker but the sound has not changed (((
then I made out the entire engine but did not manage to find the cause of knocking (((
foto all http://vk.com/albums20621392
P.S. Sorry for my Englisch language
Re-check valves I think you can set them in the wrong position and it will make them sound bad....?
that means not true test position ??Mauser wrote:Re-check valves I think you can set them in the wrong position and it will make them sound bad....?
Cam chain , cam shaft might be fooked too as the rockers were totaly caput , valve adjustment ( do it with the cover of , movig the rear wheel in gear its not as good ) , what play have you got on the decompressor lever ?
» What does the XR650R need?
» RIP 04 XR650R
» RIP 04 XR650R
