Baja Designs Squadron Pro headlight upgrade
Post  desertair27 on Sat Oct 14, 2017 8:46 pm
Just received a Baja Designs Squadron Pro headlight and hoped for an easy plug and play hook up,no such luck.
Anyone have any experience installing one these babies?
Any help welcome!
desertair27
XR650R Year : 2006
Re: Baja Designs Squadron Pro headlight upgrade
Post  Mauser on Sat Oct 14, 2017 9:05 pm
Isn't it just 2 wires ?....positive and negative ?
Post  desertair27 on Sat Oct 14, 2017 9:15 pm
Yes new light has 2 wires only,black=negative? White= positive?
Plug is different from stock headlight plug which has 3 wires.
Installing one of these also.
https://www.bajadesigns.com/products/skene-motorcycle-dimmer.asp
desertair27
XR650R Year : 2006
Post  Mauser on Sat Oct 14, 2017 9:48 pm
Does your stock headlight have a dipped beam and high beam ?, would guess 3 wires are high, low and ground ?....
If yes then either of these positive wires will power your new LED light, any wiring diagrams for the fancy dimmer ?
