vapour trail tech speedo
hi i have fitted a vapour trail tech speedo with rev counter worked fine the speedo works when in sleep mode the speedo works start xr up speedo shows 0 mph please help someone many thanks mike
Re: vapour trail tech speedo
michael mosforth wrote:hi i have fitted a vapour trail tech speedo with rev counter worked fine the speedo works when in sleep mode the speedo works start xr up speedo shows 0 mph please help someone many thanks mike
Check to make sure the magnet is properly set in the front disc. Also when you park the bike make sure the magnet is not near the vapor's pick up on the front brakes, this will cause the vapor to stay "0n" and will prematurely exhaust your battery. I believe only two wires can be installed wrong, the male / female ends are similiar, check your wiring, then the placement of the magnet in relation to the vapors pick up, may want to check the battery if everything else is correct.
Post your findings please, thanks and welcome.
xabntroop
the battery in the vapor is empty in about 1 year so order some extra on ebay for cheap (cr2032 button cell)
but i think its some problem with youre magnet or counter or the wiring is defect?
check the wire where it moves alot when you push youre front fork in
good luck
good luck
» Vapour Tech Help
» vapour tech problem
» temperture guage set up
» The trail tech puter
» Trail Tech Tachometer installation
