dyno run of my bone stock XR650R
Re: dyno run of my bone stock XR650R
Excellent I've been planning on getting mine dyno'd soon, it'll be very interesting to see how mine compares to that but I've been very curious what the XR will put out. I used to have a SM630 that peaked at 41HP, but that's a long and sad story I Cant wait to see what you have to do to nearly double the HP Taking notes and watching eagerly
BTW, Disalvo hu? You know I've got to ask, any relation the Jason?
This was on a dynojet 150 and is rear wheel hp. Was thinking more like 58 to start with but it clearly can get better. Not related to Jason, everyone always asks. Motors going to be apart for a while. Lots of things to change. Going to try to take it to Pikes Peak in June and set a record with it.
Figured I'd be like everyone and ask Very interested to see where this build goes
Been researching and most other builders are not quite as extreme as my plan. We have been working with the RMZ450 and made 65hp with a big motor so the XR should be doable.
xr 780cc
dont think you will find another xr like this one will post pics when completed your's looks very good mate
hi
hi mate engine was built by mw racing for the british supermoto - this was the secound enigine he built and paul from www.650r.co.uk sold it to me he did have both engines if you look on his website under used bike it will tell you more about it
im just near finish build just waiting on some small
thanks
will post pics when completed and full spec
spent allot on this bike but some bits still to collect when i get over to california
thanks
Do you know if anyone around there has a fuel tank that's made for crf plastics? I think its a Monnier.
hi
yes paul will have he has loads parts and some amazing xr 's in his collection if you go to www.xr650r.co.uk web site
look at fuel thanks
look at fuel thanks
Ok I have seen the site before but it didn't say the tanks were in stock. Thanks. I have already thrown the stock one away
rebuid progress?
hi , hows the project going?, ive been modding my brp for a year or two, its running handmade airbox, exhaust, lefthand converted fcr43.5mm carb with h/made v/stack, max ov/size valves, retainers/springs, modded c/chamber, ports,modded alcohol ross piston to12:1 comp ratio, falicon rod kit, xr400 ign, any help/info i can provide?
[img][/img]
[img][/img]
Last edited by temporary kiwi on Fri Aug 16, 2013 4:12 am; edited 2 times in total (Reason for editing : photos)
Is that stock standard at sea level?michelle.disalvo97 wrote:https://2img.net/r/ihimizer/img707/4233/xr650stock.png
Nice looking ride - Where did you get the black plastics?temporary kiwi wrote:hi , hows the project going?, ive been modding my brp for a year or two, its running handmade airbox, exhaust, lefthand converted fcr43.5mm carb with h/made v/stack, max ov/size valves, retainers/springs, modded c/chamber, ports,modded alcohol ross piston to12:1 comp ratio, falicon rod kit, xr400 ign, any help/info i can provide?
black xr
xr's only sell them, 'ufo' brand, the f/tank in photo is painted stock tank, paint didnt last, now got black clarke 16l
» Missing that throttle hit
» HO STATOR VS STOCK
» Top end noise?
» Top end noise?
