Robby's BRP thread
Robby's BRP thread
This will be my build thread which will list everything I do with my bike and be continuously updated.
2000 xr650r with California plate
mods:
uncorked
edelbrock carb
stage 2 hot cams
GPR stabilizer
Baja dual sport kit (and 200w stator)
radiator guards
ims 3.7 gallon tank (will be getting a 4.6 soon)
wider foot pegs (with the foot peg mod so they don't fall off)
shark fin on the back disc
rear fender sub frame (based of one scott summers used to sell, but custom built to be stronger)
future mods/installs:
dash board which will include: USB and 12v chargers, lights for blinkers and high/low beams, will either make my own speedo using an arduino using the existing parts of my broken trail tech vapor or most likely buy a new trail tech vapor
ims 4.6 gallon tank
heated grips(maybe)
passenger pegs
Pics:
mods:
uncorked
edelbrock carb
stage 2 hot cams
GPR stabilizer
radiator guards
ims 4.6 gallon tank
heated grips(maybe)
passenger pegs
Pics:
Last edited by Mauser on Fri Oct 25, 2013 8:07 am; edited 1 time in total (Reason for editing : Added pictures...remove the part after the jpg to insert)
Re: Robby's BRP thread
How do you like the Edelbrock pumper carb over the factory non pumper carb?
I bought mine with all of the listed stuff, I probably would have left it stock if I got it stock just because it's reliable and you can find those parts easier, but man oh man am I loving that edelbrock, there's no choke, it works better at altitudes (I live at 700ft but just took the bike up around 8000 and the thing had no issues with power at any point in the rpm band. It's also extremely responsive, the only thing that was a bit weird to get used to was that with the stock carb you can hear that click when you go through the kicking procedure but there is no click with the edelbrock, it's no different, just no audible click to let you know you're doing it right so when I was first getting used to the drill it was a bit harder but once I got that first 10-20 kicks it just became habit and it'll start up cold with one kick nearly every try.
The click is from the auto decompression system on the stock cam.RobbySkateboard wrote:I bought mine with all of the listed stuff, I probably would have left it stock if I got it stock just because it's reliable and you can find those parts easier, but man oh man am I loving that edelbrock, there's no choke, it works better at altitudes (I live at 700ft but just took the bike up around 8000 and the thing had no issues with power at any point in the rpm band. It's also extremely responsive, the only thing that was a bit weird to get used to was that with the stock carb you can hear that click when you go through the kicking procedure but there is no click with the edelbrock, it's no different, just no audible click to let you know you're doing it right so when I was first getting used to the drill it was a bit harder but once I got that first 10-20 kicks it just became habit and it'll start up cold with one kick nearly every try.
You running a stage two you have no auto decompression, hence no click.
» The men behind the BRP thread!
» The Jokes-thread!
» disregard thread.
» NOT another 68 68s thread, please read
» MA$TER_E's Project Beasty
» The Jokes-thread!
» disregard thread.
