kickstarter seal
kickstarter seal
Hey all I have a small leak around the shaft where the kickstart lever bolts to,my question is can the replacement seal be changed from the outside or does the whole crankcase cover have to come off and it goes in from the back? I've got the seal and all help will be greatly appreciated.
Re: kickstarter seal
It presses in from the outside but without pulling the cover you might struggle to get the old 1 out without damaging the needle bearings behind it....I would just pull the cover not a big job and change the oil whilst your there...and check the lower screen filter mesh as well
I think so yeah. Screw two woodscrews in (carefully eh?) & pull it out, and tap the new one in.
Thanks all I will monkey with it this weekend ,I'll try from outside and if its too tricky I will take cover off ...ride on
Thanks to all changed both seals kickstart and the sprocket on the other side ,I used two drywall screws and with a pair or side cutters I was able to walk both out quite easily...no more leak and the seals were cheap too .
Right on Wetdog,
always goo to hear things work.
Off topic completely, I have been wearing that irritating2me pumpkinhead because I thought I had to, being a noob & all - know you do not, you can change, you can even put a nice piccie of a slutty girl in there!
Hold on a sec, now there's an idea ......
wetdog wrote:Thanks to all changed both seals kickstart and the sprocket on the other side ,I used two drywall screws and with a pair or side cutters I was able to walk both out quite easily...no more leak and the seals were cheap too .
Great news and thumbs up to Burp....I knew if I waited long enough he would have 1 good idea this year
Now do it again on your new seals and take some pictures for the website...you did say they were cheap ?
» 02 honda xr650r kickstart binding not spinning with video
» How to tell if I've blown a fork seal??
» messed up or leaky fork seal
» Leaking countershaft seal (while in Morocco)
» Crank seal leak - Stator side
