Fork oil change - lifting the piston rod up the spring
Re: Fork oil change - lifting the piston rod up the spring
Good idea, but not a huge job to pop the forks out and change the oil whilst your messing.
» Torque #, lock nut on the front fork piston rod?
» Fork spring specs
» Fork and shock spring supplier in EU
» Help rear shock!
» Piston oil spray jet
» Fork spring specs
» Help rear shock!
