DC system. Hight output stator
My new purchase is running a stock stator but with a complete DC system (Including Headlights) with a small battery.
I'm looking to put in a Baja Design Stator single output into the aftermarket Baja rectifier.
It seems to me it should be as easy as swapping out the one stock stator for a H.O. stator.
Am I wrong in this thinking?
Re: DC system. Hight output stator
1bigrn wrote:My new purchase is running a stock stator but with a complete DC system (Including Headlights) with a small battery.
Depends on what you call easy, you will need to chop the plugs from either the statos wiring or the bikes wiring as they will have different connectors and then you will run out of connections on the stator side as the bikes wiring has a lot more connections lol.
Have fun and get plenty of connectors handy
Wiring Diagram for D/C system single output
Would anyone have a wiring diagram for single output feeding out 200 watts through a reg/rect and to a battery.
Ricky Stator has a diagram on their site but it shows two out puts and it only shows 100 watts.
Thanks,
AA
Thanks,
AA
» stator ebay
» Stator output
» Rewound stator voltage output??
» XR650R engine power output
» Stator output
