remove radiators to adjust valves?
Page 2 of 2
Page 2 of 2 • 1, 2
there's a lot different
Somewhere on the Honda website there's a page that Ogilvie goes into some detail about the development of the XR650R. Basically, the XR600s were being run at 680 or something and the engines grenaded at about the same mile marker every time.
If I can find the page I'll post it here. But a quick search didn't have any joy.
Here's another useful page though. There are a lot of solid ideas here that can be applied to other areas on the bike. Like the idea of using guards that flex instead of firm metal guards. And I HOPE this finally solves that silly argument in another thread about drive chains!!!
: http://www.xr650r.net/bruce_ogilvie.htm
Bruce Ogilvie’s list of tips on things American Honda has discovered or learned over the last year of testing and racing the big XR.
THINGS RACERS NEED TO KNOW
Read and follow carefully the February/March Wrenchnewsletter for conversion to full power competition mode and for right footpeg installation. They recommend checking the right footpeg bolts for tightness on a regular basis, about 300-mile intervals.
Final drive gearing of 14/45 for BITD and 15/48 or 15/47 (Mexico) for SCORE events offering a smoother power delivery and the best (forwards) wheel placement. (Stock is 14/48)
Remove the brass reserve from the petcock and run in the on position.
Do not use a rear mousse or tire insert. Use only a heavy-duty tube.
If you use the stock fuel tank, you must remove the white plastic insert so our (Honda pit) dump cans are able to completely fill your tank.
MORE TIPS FOR EVERYONE
The air filter is held securely in place by the left sidepanel. Be sure the front lower clip has adequate tension. It can be bent or damaged by a riders boot or other impacts, which decrease tension on the air filter and can result in dirt bypassing the air filter at the front lower corner.
With only a 1.7 quart oil capacity, usage becomes more critical (1 pint low is more than a 25 percent reduction in total capacity). Be sure to check oil levels in 200-to-300 mile intervals. To get a proper dipstick reading, the engine must be left at idle for 20 to 30 seconds. When racing, idle into the pit on which you plan to check the oil. Also watch out for overfilling; too much oil can destroy the crankcase seals.
A stock XR650 will run better on pump gas than a high-octane race fuel, which needs a higher compression ratio to be effective. (All gas in the Honda pits is Chevron 92- or VP 93-octane unleaded.)
Keep the rear wheel adjusted as far forward as tire clearance allows. The bike turns and handles better and is more stable with the wheel adjusted closer to the swingarm pivot.
The stock chain uses a staked/clipless master link (endless chain). A bike with this much torque will break conventional clip-type master links. Using one is asking for a race failure.
Honda sells the D.I.D 520 ERV2 chain (0-ring with staked master link). The Honda part number is DIDS2OERV2-120. Team Honda has been using this grade of chain since 1994. A special tool is required for staking the master link (also available at your Honda dealer). The stock XR650 chain is also very high quality and meets or exceeds the ERV2 strength measurements.
The rear fender bolts tend to come loose and should be checked regularly or have a thread-lock applied.
Inspect on a regular basis the spring-loaded part attached to the choke plate on the carburetor rear intake opening. If the spring breaks from fatigue (from excess running with the choke on or half on), it can lead to the flapper being drawn into the combustion chamber and cause engine failure. An alternate solution is to remove the flapper and spring from the choke plate, which can be done while still in the carburetor. The only drawback is the bike might take three kicks to start when cold.
The owner’s manual is incorrect: reserve is actually 0.53 gallon.
]Install a second rear rim-lock in the rear wheel. Safety-wire spokes in both wheels after break-in (tighten spokes and balance wheels also).
If you have experienced a boil-over situation with your coolant, consider switching to a radiator cap with a 1.6 or 1.8 rating (stock is 1.1). Honda doesn’t make a 1.8, but a KX8O cap is rated at 1.8 and will fit. The downside to going to a higher rating is it puts more pressure in the system, especially the hoses and fittings. This increases their susceptibility to punctures and other damage. Remember, this liquid-cooled bike should not sit and idle for long periods without airflow through the radiators. Additionally, the system is designed to boil over and has a coolant catch to handle the escaping fluid. This does not equal overheating, a common misconception.
The Baja race bikes use a 1.8 cap without the overflow tank and thermostat to save weight. They are able to get away with this by careful bike warm-up and racing with the bike wide open. These mods are not for the average rider!
The power-up kit is the same as used by Johnny Campbell and company and adds about 10 horsepower with a higher-compression piston, different cam and a stronger cam chain.
Honda also leaves the chain guide alone because it believes the polypropylene part will flex with a hit, while a metal guard will bend and do more damage.
Cool
Has anyone taken out the little choke spring thing? I cant realy picture what they are talking about. How the heck do you safty wire spokes? I wonder what my bike would feel like with 10 extra horse power, Maybe I will install the power up kit during the 50,000 mile top end rebuild! I doubt it though. I still owe more than the sticker price of my bike more than two years after buying it! I am never buying a new bike again! I saw a built 07 on craigs list for 2900 dollars! Im getting way off topic though, good info Bump, thanks. -Matt
Good stuff
Good stuff from Ogilvie. Thanks Bump.
Matt:
I picked up my '02 pig today, but left the mechanic the old parts. I did scope them out, though.
Apparently, if you are a dumbass like me, the first things to go when running low on oil are the rockers and cam. The cam lobes looked somewhat torched and a bit scarred. They ate up the bottom of the rockers, causing a slight clearance issue. I was very lucky to sustain such little damage.
All is well now. I just rattled the neighborhood windows on a test ride (it's all good - the neighbors do the same to my windows ), and she's running great.
I'm going to sell this one and grab a trailer to haul my other one around for those occasional long distance hauls to other states.
Dave
Matt:
Dave
Depends on the gear I reckon
But if you are talking about terrain I'd guess the sand guys could. Or one of those long sand washes near Cal City could easily be a fourth gear flat out rooster tale for miles. Not so much for you folks who live with trees.
mamacone wrote:Who is capable of running the pig flat out all the time? Nobody I know or have seen. Would like to see the results.
Re: remove radiators to adjust valves?
Rd650 wrote:Someone correct me if I am wrong. But the 650r has a tendency for the stock intake valves to sink into the seat taking up the clearance at the adjuster.
Yes the intake valves wear and slowly sink into the head thus taking up gap. They need to be loosened. Once they start to go it actually happeens faster and faster. Worst case is the valve surface get so thin the valve sucks up into the head all of a sudden. I rarely check the exhaust because they never seem to change. I'm having an intake valve only job being done right now.
XR Gene
Matthendurocat wrote:How many miles did you go before this valve job? -Matt
10-13 thousand miles.
XR Gene
I don't have to remove the radiators either. As above, just bend the feeler gauges.
____________
Diamond Jewellery
bath remodel orange county
____________
Diamond Jewellery
Page 2 of 2 • 1, 2
» VALVES, BURNT OUT??
» noisy valves?
» Valves were super tight?
» Do the Unabike rad guards fit on the Fluidyne Radiators?
» Clarke 4.3 Gal. install
» noisy valves?
Page 2 of 2
